on the oil pump on this engine 1ZZ FE 2000
CELICA, can the presure be changed by changing the the spring, was looking at some pictures and seen what apperred to be a presure valve monted on the front of the oil pump. the car is lossing oil presure after it heats up and rattles a little and the light flashes some and then stays on, also where car i get a engine manual for this engine, where is the best place for parts. or is the motor junk an need replacing, where would you get a long block. any help would be apprieated
tater
