flywheel difference help..
I need to know if the 3s-ge flywheel is the same then a 3s-fe flywheel.
I done a manual tranny swap on a 1990 celica gts with the 5s-fe and the starter does seem to reach the 3s-ge flywheel. ( swaped the bell housing from a 87 camry manuel tranny cause the bell housing for the 87 celica had the starter under the exaust which i would of got to change the exaust on the 5s-fe) I did not have my camry flywheel on hand to check
So if someone could give me the size difference between each.
thx in advence..
Charles
CP. Performance & Modifaction
450 572 1686
