Quirky Q 'bout 3vz/2jz pistons and propane
I've got a Lexus ES250 and want to swap in a 3vz motor..okay thats the easy part. I live in CA and was thinking of getting around the emissions swap problems and change to propane. My idea was to set it up for a propane/carb setup. Ok thats not really anything I cant figure out...What I thinking about is spec's for putting 2jz pistons (3.0L) into this 3vz engine (a stretch..i know...)....even with some minor machining for wristpins or ???. I would already consider milling the heads too, but I"m not sure how much I can get out of that with t belt problems and intake alignment problems. The reason is you don't really reep the bennefits of Propane untill 13:1 or 14:1 compression. Other ideas would be welcome. I'm currently in Iraq and trying to find spec's for these details is a little difficult right now. Just planning for the trip home...Also...I'm just a contractor, not a soldier.
Also, the 3vz has a distributor, but how much of it is "computer controlled"? I would consider going to a stand alone ignition if need be. I think some really nice horsepower could be had with this setup. And if this isn't hardcore enough...sorry in advance.
Thanks,
90' ES two-fity, balanced motor, head work, home built intake, lowered, wheels, window tint and some stereo upgrades, next...building my headers.
