how to check Wheel's offset? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 10-11-2003, 10:39 PM   #1 (permalink)
View Tubbyc's Photo Gallery
I am puzzled...How do you check the offset of the stock wheel without physically taken it down and measure it? and how do you determine which aftermarket wheel will fit onto your car without any problem?
Tubbyc is offline   Reply With Quote
Old 10-12-2003, 12:17 AM   #2 (permalink)
View Deep's Photo Gallery
Dunno if this will help,
Deep is offline   Reply With Quote
Old 10-12-2003, 01:06 AM   #3 (permalink)
oh.. I mean is the offset of the stock wheel written somewhere?
if the stock wheel's offset is 40, then what is the range that can be considered to be a good fit? (ie. 35-40. 38-40)
Old 10-12-2003, 03:02 AM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Yeah its written somewhere along the rim, not sure on which side it is. but on steel wheels its usually stamped near the bolt surface, on alloys sometimes its between the spokes.
Old 10-12-2003, 03:17 PM   #5 (permalink)
ECHO....Echo....echo....
BenG's Avatar
View BenG's Photo Gallery
recommended offset will change based on the width of wheel you want to use, so there is no 'recommend' range based on your offset unless you plan on sticking to a wheel with the same width.
BenG is offline   Reply With Quote
Old 10-17-2003, 09:36 PM   #6 (permalink)
View Mosquito's Photo Gallery
I recently asked http://www.discounttiredirect.com/ what the offset was for 03 camry, this was their response
The offset of the OEM wheel is a +45mm. If you install aftermarket
wheels, the following offsets can be used:
7.0'' width wheel : +35mm to +45mm
7.5'' width wheel: +35mm to +45mm
8.0" width wheel: +38mm to +40mm
I also asked tirerack, they said 46mm.
Mosquito is offline   Reply With Quote
Old 10-18-2003, 11:50 AM   #7 (permalink)
Wheels Direct rep
soulibrium's Avatar
View soulibrium's Photo Gallery
to chk offset you gotta have 2 rulers. both flat and straight. first place the first ruler accross the back of the wheel face. so you gotta have a ruler or a flat surface that will be atleast the diameter of the wheel. now place the 2nd ruler perpendicular to the flat surface and measure the back plate with the edge of the flat surface.find that number in CM. ok now that you got that number its called the backspacing. now you find the width of the wheel. if its a 6" for example, the the dead centre is 3" wich is 7.5cm. ok. how with that ruler if you measured lets say 12.5cm which is 125mm then you do 125mm - 75mm that will give you 50mm. so for this example your offset is 50mm
got it?
soulibrium is offline   Reply With Quote
Old 03-30-2004, 09:42 PM   #8 (permalink)
Mighty Flying Family Sedn
View Mighty~Mart's Photo Gallery
so if i choose to use a 18x8.5 or 18x9, would my tires rub
Mart~
Camry Gen 5 SE
2.4L I4 DOHC
Stock 16's
Totally stock
Mighty~Mart is offline   Reply With Quote
Old 03-31-2004, 12:45 AM   #9 (permalink)
View Nx2k's Photo Gallery
if u keep the same width, you can go up to 10 either way and you'll be fine.
signature suspended. Please read the rules. No animations.
Nx2k is offline   Reply With Quote
