how are twin turbo exhaust manifolds set up - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-04-2003, 02:33 AM   #1 (permalink)
View crazy_camry's Photo Gallery
by my question, i mean, do half the engine's exhaust runners go to one turbo, and the other half of the exhaust going to the other turbo, so effectively having 2 manifolds?
or do all the exhaust runners split up to go to both turbos? do i make any sense?
crazy_camry is offline   Reply With Quote
Old 11-04-2003, 03:51 AM   #2 (permalink)
*The SV-11 Driver*
idrivemyself's Avatar
View idrivemyself's Photo Gallery
are you talking about a v6 TT setup, or a TT setup on a straight 6?
2001 GTI VR6
1986 Camry (SV-11)
idrivemyself is offline   Reply With Quote
Old 11-04-2003, 06:55 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
With a V engine layout (V6, V8, etc) theres a turbo coming off each head, so yeah theres 2 turbo manifolds.
An example of a twinturbo setup on a I6 would be a MKIV Supra Turbo. Its actually a sequential twinturbo (one big turbine housing with compressor housings on each end).
Also the Nissan Skyline (twinturbo I6), but i'm not sure how the turbos on it are setup.
"Skoolin' the unlearned!"
Old 11-04-2003, 09:25 AM   #4 (permalink)
one turbo is one too few
bgrieger's Avatar
Gameroom cash: $307250
View bgrieger's Photo Gallery
There are several variations on this depending on what you mean by twin turbo. Sequential setups like the MK IV use gates to allow both turbos to use the same basic manifold, but one to see more gasses early to improve spool and then balances off to equalize pressure. This setup tends to be hard on one turbo vs the other. Ask a MKIV owner how #2 is after going BPU and you'll get a bit of a cringe...
Some cheap twins use the same log manfiold as most singles (4 and inline 6 setups) with 2 turbos slapped on. Some use 2 seperate manifolds (better for inline 6, as it reduces expansion due to heat warping of the flanges by making them seperate).
Some V heads use a manifold on each head with one turbo, or a bridge pipe to tie the 2 manifolds together and run 2 turbos on the now one manifold (for pressure balancing or to bring everything to one side of the engine).
There are more varieties than you can shake a stick at really, but these are pretty much all the common basics. for twin or sequentials.
Bob
