It's official... I'm blowing Oil... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-16-2003, 08:29 PM   #1 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
Any ideas on what it could be?
It's under heavy acceleration.
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
90CamryDx3SFE is offline   Reply With Quote
Old 11-17-2003, 10:42 AM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $696165
iTrader Score: 6 reviews
View EKam's Photo Gallery
Noob vote - head gasket?
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 11-17-2003, 10:57 AM   #3 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
valve seals.
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 11-17-2003, 11:21 AM   #4 (permalink)
View Deep's Photo Gallery
^ or rings.
Deep is offline   Reply With Quote
Old 11-17-2003, 06:36 PM   #5 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
take out your pcv valve and see if it still does it, if its bad you might be building too much pressure in the head blowing oil though the valve guide seals
-Nick
Nick is offline   Reply With Quote
Old 11-17-2003, 11:27 PM   #6 (permalink)
Boro Box Pilot
boroEF's Avatar
Originally posted by Deep
^ or rings.
if rings were shot, wouldnt he smoke blue even when he's not accelerating hard? that's just what i'd think would happen.
The boro guru
boro song
"boro boro boro
Old 11-17-2003, 11:36 PM   #7 (permalink)
From what I've seen, bad valve seals will give a puff of blue on startup. Bad rings will give blue smoke from idle but not in huge amounts for you to notice, at redline however, you can see it in your rearview. A plugged PCV could also do the same, but most often you'll see oil running out of the PCV hose or valve.
Old 11-18-2003, 04:41 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
3S-FE's have a PCV system, but no PCV valve.
"Skoolin' the unlearned!"
Old 11-18-2003, 09:33 PM   #9 (permalink)
Should I try a heavier oil???
I'm running 5w30 right now. Should I maybe step up to 15 or 20 weight?
Old 11-18-2003, 09:47 PM   #10 (permalink)
View jm_2thow's Photo Gallery
throw some gear oil in..lol
jm_2thow is offline   Reply With Quote
Old 11-19-2003, 09:55 PM   #11 (permalink)
Ok.. so I checked the PCV, or at least what I thought was the PCV tube that comes out of the valve cover. I wasn't able to actually pull the tube and see if it was clogged. But theres no visable oil oustide the tube.
Any ideas of how to check the tube? Haynes doesn't offer mush on the engines without a PCV valve.
