Harness Replacement Help Please!
I have a 92 Celica Coup GT 5sFe 5Speed.
The Fuel line split at the FPR and Ignited the Distributer Cap out the bottom side begining what has been known as a "CRAP" situation for muah!
I purchased a harness "91-93 5speed" but it's not correct. I went ahead did the repairs and put the harness in "hopeing to mod a little". HAHAHA! anyhow. Thought all I had left to do was run a Knock sensor wire and the #4 wire for the tps as the harness I currently now have only has a 3 wire tps connection. Turns out that Two out the the Four Base Harness connections to the ecu are different. original connectors are 13 pin/8 pin across and the Older style harness that is installed is 9 pin/5 pin across. I Purchased the Complete immport Pin Kit off the Truck. I need direction. Were can I get the wire charts so that I may swap the connectors. the colors are all not the same. so I can't just swap em' with out charts. I cant trace the old ones because of fire damage on the old harness on the engine side. HELP! just need those charts. anyone? direction? please and thankyou.
