Kooky idea for an oil temperature sensor... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 11-23-2003, 08:50 PM   #1 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
What if we were to take the probe from a Oil temperature sending unit, and thread it into a braided line (like that of which 88 LE made for his connection to his turbo), and take temperature from there???
Here, I'll draw a picture in a minute.
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
90CamryDx3SFE is offline   Reply With Quote
Old 11-23-2003, 08:56 PM   #2 (permalink)
Here's the picture... I hope you understand it.
Old 11-24-2003, 12:29 AM   #3 (permalink)
*The SV-11 Driver*
idrivemyself's Avatar
View idrivemyself's Photo Gallery
that might work, but i can already see one flaw in the design. where the sensor is located won't be the ideal spot because the sensor won't be in the oil's direct line of flow. basicly the oil will get caught up back in that pocket and sit. not moving with the flow and circulating around the sensor to get the most accurate reading. i hope my babling makes some amount of sence to you, if not heres my design which might prove to explain what i'm getting at.
2001 GTI VR6
1986 Camry (SV-11)
idrivemyself is offline   Reply With Quote
Old 11-24-2003, 12:31 AM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
flow has nothing to do with pressure...
-Nick
Nick is offline   Reply With Quote
Old 11-24-2003, 06:38 AM   #5 (permalink)
We're not talking about pressure though, we're talking about temperature...
However, if the pressure is constantly changing in that line, then the oil must be changing itself out a little bit.
Old 11-24-2003, 10:20 AM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
It should work, but you could use a copper line or just a normal hydraulic line with the correct ends. would be cheaper than a braided hose, plus hydraulic hoses have internal braids inside the rubber.
Old 11-24-2003, 02:07 PM   #7 (permalink)
Where else could you place an oil temperature sensor without having to drill the oil pan, and make a welded fitting???
Old 11-24-2003, 02:26 PM   #8 (permalink)
Nick's Avatar
you could make a threaded fitting...
or you could just put the wire across the oil pan gasket and put some silicone, that would seal it up pretty good
-Nick
Old 11-24-2003, 02:37 PM   #9 (permalink)
I'm not on to take that kind of risk (silicone and all)...
I'm looking to do something simple, and easy, with decent reliability.
It's ashame this car doesn't have a built in oil cooler.
Anyone know were I can find a sandwich plate for the 3SFE filter???
Old 11-24-2003, 07:45 PM   #10 (permalink)
View DIRTBIKEZ's Photo Gallery
You can get an oil cooler off an equipted 5sfe.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 11-24-2003, 07:51 PM   #11 (permalink)
Thus still presents our dilemma...
Where do we take the in and out lines for the cooler from?
Someone posted in the past about having a sandwich adapter for the in and outs.
Anyone know where to find one? (I asked this above).
I'll also need to look at how exactly I would mount this oil cooler.
*Adds to list of winter projects*
Old 11-24-2003, 08:13 PM   #12 (permalink)
Its a fitting that mounts between the block and the oil filter. They arent too difficult to find. Then you can mount the cooler infront of the radiator and/or condensor.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
Old 11-24-2003, 09:07 PM   #13 (permalink)
I know what the sandwich adapter is. I'm just wondering where to find one.
Can I find one made specifically for a 3S-FE, or will the adapter from a 5S-FE fit it???
If I find this fun stuff out, then I'mma turn this into a Winter Break project in my garage :-D
Old 11-24-2003, 09:41 PM   #14 (permalink)
Heres an example:
Summit Racing
From what I remember its the 3/4"-16.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
Old 11-25-2003, 10:43 AM   #15 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The oil cooler on a 5S-FE has coolant circulating through it.
Its just a ring that bolts onto the block.
"Skoolin' the unlearned!"
