To cut a long story short, can the pressure modulator in ABS brakes cause a pressure drop in brake lines when ABS is disabled, e.g. by pulling the fuse? Given that the modulator itself is not defective. I don't suppose I can diagnose it myself, the unit being sealed precision assembly and all.
Comparing two similar cars, one with ABS and the other without. The brake pedal has to be pushed really hard and quite far before the brakes start to lock up on the car with ABS. ABS being disabled at the time by removing the fuse. I have ruled out worn pads, malfunctioning calipers, air in the system and differences in tires. The brake pedal feels firm right from the start once the vacuum in brake booster is released.
Any tips for further diagnosis are greatly appreciated.
Here is the long story:
Brakes on a Toyota Carina '97 2.0l 3SFE
