vvtl-i problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 12-25-2003, 06:04 AM   #1 (permalink)
View bagadonutz's Photo Gallery
vvtl-i problems
my mass air flow was bad so i replaced it (the dealer wanted 331 dollars to replace it, right! i did it for a hundred) my celica was like the day i bought it. now three weeks later i lost my vvtl boost. at 6000 i feel a sort of engagement but nothing happens it just sound like the engines straining, no growl, no power. could it be the oil sensor that engages the cam? i don't think its the ecu because it seems to do somthing at 6000 rpm.anyone had this problem? thanks in advance
bagadonutz is offline   Reply With Quote
Old 12-25-2003, 06:06 AM   #2 (permalink)
sorry forgot 2000 celica gts with 60,000 mi.
Old 12-25-2003, 08:01 PM   #3 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
I think there is a Toyota Service Bulletin for the 2ZZ-GE engine; looks like there is a manufacture problem with the bolts that engage the VVTL-i system, they get worn down so much the system fails to engage the "higher profile cam" thus you are not getting the kick in the pants you used to get when the car was new.
I cant remember where I saw this info, it was probably at the Team Celica forum site (www.tcforum.com)
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
Old 12-25-2003, 08:10 PM   #4 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
yep, they did a recall on it.....here in canada, they found out about the problem after the engine hitting 100,000km.....
hopefully your's is still under waranty
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 12-26-2003, 03:09 PM   #5 (permalink)
i can't find that TBS bulletin anywhere do you have a link?
Old 12-26-2003, 04:54 PM   #6 (permalink)
View Deep's Photo Gallery
Its the infamous lift bolt problem. Basically its a bolt that wears out and doesn't allow the motor to hit lift. The shitty running condition is because the ecu thinks the car is in lift and throws in extra fuel and timing.
try searching www.alldata.com .
Deep is offline   Reply With Quote
Old 12-26-2003, 08:31 PM   #7 (permalink)
GT-i Crew
lcarocha's Avatar
Here are the lists of TSB for the 00-04 Celicas.
Moderator, make this a sticky note, I think people are gonna need this.
http://www.newcelica.org/forums/show...&threadid=4338
TSB (#EG010-03) for certain early models
Might as well read the whole thread at
Team Celica Forum
Luis C.
2nd Gen 3S-GE
Caracas, Venezuela
Old 12-27-2003, 04:57 AM   #8 (permalink)
thanks for the bad news, i guess it time to rip it apart and take a peek, hopefully it just worn and not busted off. how can a car manufacturer make an engine that a bolt breaks in and not stand behind it.
Old 12-27-2003, 09:18 AM   #9 (permalink)
Did you read the threads? Toyota will fix it, call them and take it in for servicing.
Old 12-27-2003, 09:31 AM   #10 (permalink)
i have 62000 hopefully toyota will goodwill the repair. they still will charge me 80 dollars for the diagnostic if toyota doesn't cover the repair, in which case i'll end up doing it myself.
