Need help with oil light coming on in AE95/4AGE setup
I'm new to Toyotas, and I have an issue that has cropped up on my car in the last week or so. It is a 1989 AWD Corolla with a 4AGE 16 valve engine in it. I suspect the previous owner didn't divulge much information about the car when I bought it a month ago, but I don't blame him. I didn't ask enough questions when I was looking at it. Anyways, here I am asking for help.
The car was built for rallying in 2001, and it has a rollcage. THe engine swap was done at this time as well. The engine runs fine, pulls to 8000 RPM, idles fine and starts almost instantly in any temperature.
Lately, the oil light (good ol' dummy light on the dash) has been coming on at idle after the engine has warmed up and been driven for 15-20 minutes. The longer I drive it, the more the light comes on. I've seen the light on up to 4000 RPM recently. If I was really having a problem with oil pressure, the engine would have seized a while ago with the way I drive it. I don't care much about this car, but I don't want to fry the engine either.
So, what with the engine swap and all the other things done to the car, I'm thinking there may just be a loose wire somewhere that is causing the light to come on. Is this possible? What information would a bad sender give? Light or no light?
I'd be interested to see what the oil pressure is, but I don't want to go through the trouble or cost of installing an oil pressure gauge. Is there some way I can tap in with a temporary gauge to check the pressure in a shop?
From what I've read/seen about the 4AGE, the sender is right there on the front of the engine with a single wire coming out of it, so checking that should be simple, but what am I looking for?
Oil level isn't extremely low, about halfway on the hashmarks on the dipstick. I will add more oil, but I suspect this is not the root of the problem. What kind of oil does the 4AGE like?
Any help would be appreciated. I can get pics if necessary, and if you need any more info, just ask. I'm mechanically inclined!
Thanks,
Phil
