Replacing engine on 05 scion tc, any DIY? Need help asap! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-05-2009, 04:43 PM   #1 (permalink)
View socal tuner's Photo Gallery
wondering if anyone has useful info on replacing engine on a 2005 scion tc. I am putting the car back to stock so the built engine and turbonetics turbo kit is coming off. I need to know where the ecu is located? and how to get to it? any tips would help a bunch! what size is the axle nut? i know the motor comes out from the bottom with the rear subframe attached as one piece. Thanks guys!
socal tuner is offline   Reply With Quote
Old 01-19-2009, 01:40 AM   #2 (permalink)
just a nobody
The ECM is located behind the glovebox, should see it with the glove box out. The best route for you to take is get a manual before diving into the job. The axle nuts, I believe are 12 point 30mm.
N.E.O.
