22r & 22re - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-05-2004, 07:52 PM   #1 (permalink)
View george1's Photo Gallery
22r & 22re
I have a 1986 Toyota 4x4 P/U with a 22 R motor, I have a fuel inj. system that came off a 1986 P/U. How much trouble is it to incorporate fuel inj. system onto my motor. I have everything, head,intake inj. & wiring. Do I need a PCM?
Darrell E George
george1 is offline   Reply With Quote
Old 01-06-2004, 01:21 AM   #2 (permalink)
Trailer Trash Engineer
alltrac165's Avatar
View alltrac165's Photo Gallery
You will need pretty much everything off the donor except for the block. Computer, wiring, intake and exhaust manifold(or mount the O2 in yours somehow), fuel pump, maybe different fuel line set up(not sure on that one), afm, all other sensors and...um what else....
Not sure on ignition stuff. The computer needs to know rpm somehow, but I don't know where it gets that info from. Distributer maybe? Ignition module may be different.
You might want to get one of each side by side and see what's the same and what's different.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
alltrac165 is offline   Reply With Quote
Old 01-06-2004, 08:27 AM   #3 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
You don't need to change heads the Carbed and Fuel injection heads are the same. As long as you use both from the newer engine which started in 85 so you are fine there. The distributors are the same as well they are both electronic. Youreally just need the whole intake side of thing, wiring harness and computer. You can keep the exhaust manifold you have already too since it is the same as well.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 01-06-2004, 09:14 AM   #4 (permalink)
Thanks to all..
Darrell E George
Old 01-14-2004, 05:49 PM   #5 (permalink)
View pimpy rider's Photo Gallery
I just put a 22r-e in my 73 celica 2 days ago so i know exactly what u need to do.
your biggest concern is probably hooking up the ecu. This is easy. your one harness goes to the engine, the other one to the body. The body harness has many wires coming out of it. you need to hook up 6 or 7
The black with yellow stripe goes to your airflow sensorand to +power
the smaller black goes to your coil,tachometer
The rest all go to airflow sensor, this is easy, just match colors. There are 4 or 5, i can't remember.
I'd like to add that i recommend converting if you plan on keeping the truck. I hate screwing with carburators.
pimpy rider is offline   Reply With Quote
