Originally posted by pulsedriver
If your car did not come stock with a turbo then you can safely run a BOV. If your car came with a turbo stock then it also came with a BPV stock. A BOV will cause havoc on the MAF sensor because it will think that you have an enormous boost leak since there is no air recirculing back through it like with a BPS.
Ummmm....close, but not really.
BOV's wreck havock on any car with a mass airflow system, be they flapper door, hot wire or Karmann Vortec. MAP sensor setups are the only one that can run BOV's without problems, and that is because they meter by air pressure, not flow. THey also usually cause only minor effects, but may lead to a stall if you were to run under boost and then just step on the clutch to coast.
BOV's are also not open except when the pressure in the intake pipes is significantly greater than the manifold. The vacuum only assists the pressure in the pipes in overcoming the resistance of the spring inside the valve. Hence many have adjustment screws to set the tension, and almost every one you hear will flutter at low pressure (keeps opening and closing up until the turbo slows enough). Bypass valves tend to be open more, and hence they are lousy to release to atmosphere, and their design allows unmetered air back in. BOV's seal before this occurs.
When a BOV releases, it dumps metered air out to atmosphere, creating a short lived rich condition. In some cars, this will trigger the check engine, in others, you get a backfire or stumble. Bypass valves recirculate charge air to a point before the turbo, but after the airflow metering device.
Not all turbo cars had either of them, and none made since the 70's have BOV's (emissions regulation...no intake charge can be atmosphere dumped).
To answer the why question, the idea is to release the charge air before the shock wave gets back to the turbo. Slamming the throttle plate closed causes this pressure wave to move back through the system. Unchecked, it slams into a compressor wheel and can cause blade damage, or shaft failure in extreme cases. Venting this wave keeps the impact down, and minimizes deceleration of the turbo compressor, leading to less lag on application of the throttle again (ie when shifting).
Sorry for the length...kinda late and rambly...
Bob
