Originally Posted by concealer404
Believe so... can't say that one for sure though....
If you're going to use a 5sfe crank, why don't you get some 5sfe rods and pistons while you're at it? You know that'll all fit together.
I DO know that it's the same for 3sgte and 5sfe, though.
I am not 100% myself having not messed w/ the FWD/AWD stuff too much - my experience is w/ the supras and such; I'm just trying to see if the S series is similar to what can be done w/ the M series (for example).
If what I want to do can be done - thats what I'd be doing; using the whole rotating assembly - crank, rods and pistons. Just didnt know if there was a difference between the 5S that would matter - seems like there are a few between the years.
Also, didnt know if the block heights or the wrist pin location were different between the 3S or 5S?
