Testing fuel injectors - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-26-2009, 05:19 PM   #1 (permalink)
View Puffie40's Photo Gallery
I ripped apart a 3S-GE engine and noticed piston #4 had a bit more carbon buildup than the others. I'm going to do the usual rebuild stuff (New rings, clean the bores, ect.) But I want to test the injectors to see if I sould replace them. Can I do this myself or should I take them to a shop?
Puffie40 is offline   Reply With Quote
Old 01-27-2009, 01:07 AM   #2 (permalink)
just a nobody
It wouldn't be very accurate to test it yourself, the most you can do is to check the spray pattern. A fuel injector test machine can check the flow rate volume, and a few other things. They can also clean the injectors, and then give you readings on the before and after results.
N.E.O.
