Toyota engine code explanation - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-13-2004, 05:35 PM   #1 (permalink)
Formula One Fanatic
andyman61's Avatar
View andyman61's Photo Gallery
after studying Toyota engine codes a little bit, i'm beginning to see a lot of ge's and fe's at the end. what is this all about? are they short for something? or is it just arbritary? plus, does the stuff in front (5s, 3s, 2jz, 1zz, etc.) mean anything? i ask because honda and nissan both have some sort of organization to their codes.
Metal to burn, sparks to fly...
1992 Toyota Camry 5 Speed - 5S-FE....totally stock
andyman61 is offline   Reply With Quote
Old 01-13-2004, 06:32 PM   #2 (permalink)
My Dixie Wrecked
wedge's Avatar
View wedge's Photo Gallery
This should explain it:
BEFORE "-":
the letters indicate the engine family, for example in 18R-G
the engine family is R, in 2JZ-GTE the family is JZ.
The number(s) at the beginning is the number of the are for a certain
bottom end version (block, bore, stroke). The larger the number,
the newer the bottom end version. It may seem like the larger the
number, the larger the displacement but this is not always true.
AFTER "-":
G = twin cam (wide angle, 45 degrees or more between the intake and exhaust valves)
F = "economical" twin cam (narrow angle, around 22 degrees)
T = turbocharged
Z = supercharged
E = fuel injection
i = single point fuel injection
L = transverse mounted engine (seems to be an obsolete code)
B = twin carbs (only used on non-twin cam engines, obsolete code)
R = air injection
S = swirl intake ports (only a few made in mid '80s)
S = direct injection & swirl pot pistons (starting from '97/98)
U = emission package (Japan)
C = emission package (California)
LPG = LPG fuel
Racing is everything
wedge is offline   Reply With Quote
Old 01-13-2004, 06:47 PM   #3 (permalink)
Formula One Fanatic
andyman61's Avatar
wow, thanks a lot man! that makes a lot of sense thinking about different cars and their engines.
Old 01-13-2004, 07:17 PM   #4 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
Thats Toyota Freak 101
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
