MSD 1-2-3 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-13-2002, 02:25 PM   #1 (permalink)
View DS - TTCC's Photo Gallery
I just got my MSD-6AL ignition box today. I have been reading the documentation and it looks like it's going to be a relatively simple installation, but I don't want to jinx it! My buddy is a mechanic, so I figure that he'd be the best one to help me out. Does anyone know where I can get a good set of ignition wires made, preferably MSD or Accel 300+ wires? Also, is anyone interested in a step-by-step installation instruction set? I'll do it if people are interested, otherwise I won't bother with instructions, I'll just take pics. Let me know!!!
DS
1992 V6 3VZ-FE Camry, 5 speed!
DS - TTCC is offline   Reply With Quote
Old 03-13-2002, 05:45 PM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Sure, that would be great. If you want good wires, Ive heard good things about Magnacore. Do the 3VZ's have a distributor? Cuz I know my 1MZ is distributorless, it uses coil packs instead.
If you want, I can come by during the install to take pics if you dont have a digicam of your own.
latez.
ratko.org
Ratko is offline   Reply With Quote
Old 03-13-2002, 07:50 PM   #3 (permalink)
Banned
View goodcookiedrift's Photo Gallery
Actually I would be interested in that. I would like to know, for sure, that the MSD 6AL cannot control ignition timing under load on carbuerated engines. Is there anything in the manual that points to this?
Nick
goodcookiedrift is offline   Reply With Quote
Old 03-13-2002, 08:34 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The MSD is a ignition amplifier so it does not control ignition timing.
The MSD 6BTM does come with an extra box that allows you to retard the timing based on boost though.
"Skoolin' the unlearned!"
Old 03-13-2002, 11:02 PM   #5 (permalink)
Banned
huh? well, perhaps you could explain why numerous ppl use the msd6al in conjunction with the efi dizzy on carbed 4ages? Doesn't the ignition amplifier adjust the timing of the dizzy based on the rpm band....depending on what you're reving, it either advances or retards the ignition curve? however, i'm curious if it can adjust the ignition curve (spark) under load...many say it cannot, but i assume that MSD must have a model that can.
Old 03-14-2002, 08:41 AM   #6 (permalink)
I have heard good things about Magnacor too, but they are really expensive. I'm going to try to have a set of Accel or MSD wires made up, which should be much cheaper.
No, the 6AL does not advance or retard timing, it's just a capacitive discharge unit that provides Multiple Sparks under 3000-3500rpm. Above that, there's just one big spark.
The 3VZ-FE does have a distributor, and the 6AL (and any 6 series ignition) cannot be used with a DIS. I'll let you all know when I am going to install it. Photographers welcome!
DS
Old 03-15-2002, 05:07 AM   #7 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
jacobs sells wires for the camry not sure if it would work on ur v6 though... but they are worth a shot to ask.. maybe then have an application or a custom for ya...
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 03-15-2002, 05:43 AM   #8 (permalink)
View speedemn's Photo Gallery
You know my #. Gimme a shout (I assume you will be doing it back home in Waterloo?)
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
Old 03-18-2002, 02:47 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Did you get your MSD 6AL installed?
I installed a MSD 6A, MSD Blaster SS Coil, and a MSD 8910EIS tach adapter on my car over the weekend.
Old 03-18-2002, 09:17 AM   #10 (permalink)
I didn't have time this weekend! I want to wait until I get my coil, tach adaptor, and ignition wires. I'll let you know when it's all installed!
DS
Old 04-08-2002, 09:38 PM   #11 (permalink)
View Hemi3TC's Photo Gallery
You can get NGK spark plug wires with Metal resistor wire ( Mag wire) and the better stainless steel multi point plug ends instead of the brass ends with a small rectangular rectangle on the end of US made plug wires along with a lifetime warranty.
TRD also sells mag wire ignition wires which I use on my 1982 SR5 Corolla Coupe, TE72 along with a MSD 6A.
Hemi 3TC
Hemi3TC is offline   Reply With Quote
