Cracked sparkplug wire boot: problematic? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-26-2004, 07:19 AM   #1 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
Changed my plugs the other day and was again reminded that on my number 1 plug the boot that you grasp to disconnect the wire from the spark plug has a rip in the rubber. I don't see any sparking or glow from it, but I wanted to ask the collective wisdom of TN if this could be problematic and if I should go ahead and replace this thing as a preventative measure.
It's not that dark line on the right, the crack is on the left where you can't see it, on the cylindrical part of the plug.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 01-26-2004, 08:00 AM   #2 (permalink)
View Deep's Photo Gallery
Shouldn't be a problem, put some sort of glue on it if it bothers you.
Deep is offline   Reply With Quote
Old 01-26-2004, 10:46 AM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
i'd put a sealant on there, if water gets in, you're screwed
-Nick
Nick is offline   Reply With Quote
Old 01-31-2004, 10:20 AM   #4 (permalink)
View OEMonkey's Photo Gallery
quick way to check any plug wire for acing.
KOER, ground your test light and point it to suspect area. If the light comes on then you have a leak. you can also run the test light the length of each plug wire to check for acing.
OEMonkey is offline   Reply With Quote
