Do I NEED a new ECU for auto to manual conv.? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-26-2004, 05:34 PM   #1 (permalink)
Banned
View Talisman's Photo Gallery
Okay, the hop called me todat and asked "what about an ECU"?
I have asked people about this before and they said it was not necessary but I just wanted to check and make sure so if anyone know's for sure please let me know. The ECU does not control a manual tranny right so I don't need one? Will I run into any problems without one? Ratko, I know you did this swap so you should know. Tony, 88le, Harmer, anyone?
Talisman is offline   Reply With Quote
Old 01-26-2004, 05:38 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
http://tt-cc.com/ratko/swap/index.html
about half way down, used resistors to trick it
-Nick
Nick is offline   Reply With Quote
Old 01-26-2004, 05:42 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
SBC and SCEPTER300RR used the auto ECU too (5S-FE)
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 01-26-2004, 06:47 PM   #4 (permalink)
Banned
Oky, I was doing a little bit of research and I can use the manual ECU but I also need the manual wiring harness because of the difference in wiring? Is this true? If so, I am going to call a junkyard tomorrow and see how much those parts run. I want this swap to feel/look as factory as possible and I want it to be a simple as possible for the shop that is doing it.
Old 01-26-2004, 07:40 PM   #5 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
if you want it as factory as possible, get the manual ECU and the main engine harness for the manual ECU also.
otherwise if you just want it to work... no ECU necessary.
ratko.org
Ratko is offline   Reply With Quote
Old 01-26-2004, 08:50 PM   #6 (permalink)
Banned
d@mn engine harness is 100 dollars. ECU is only 25 though. I might just get the ECU amd let the shop worry about the wiring.
