INFO: Rough idling & stalling problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-28-2004, 07:09 AM   #1 (permalink)
View Meisner's Photo Gallery
Under the "tech" part of the forum title, I thought I'd submit this:
If you have an older (> 60,000 miles or so) engine and it is starting to show problems idling or even stalling sometimes, there's a good chance it's the IAC valve that needs to be cleaned.
The IAC valve is the Idle Air Control valve and provides a way for the ECM to allow more air to flow thru the throttle body without opening the throttle plate. This is how idle is controlled.
Because of where it's located, the IAC gets quite dirty over time to the point where it cannot open easily. Therefore, it must be repalced or cleaned. This valve is not cheap, so cleaning it makes a lot of sense.
The IAC valve is on the bottom of the throttle body. Carbon will build up inside this thing and cause the engine to not idle right and even stall. The symptoms may go away after the car warms up....or in my case, it got worse and began stalling.
To fix it, you have to take the IAC off the throttle body...and you have to take the throttle body off to get at it. There are 4 screws that hold the IAC in place. These screws are soft and strip easily. Also they tend to get frozen in place, which makes it tougher to remove them. [REMINDER: Use anti-seize when reassembling!]
Once you get it off, you have to take the IAC apart and soak the aluminum parts in a strong cleaner. A machine shop can do this a lot better. You really want this sparkling clean!
When putting it back on, you need to use a new gasket between the TB and the IAC valve.
Steve
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 01-28-2004, 09:40 AM   #2 (permalink)
View luisitol's Photo Gallery
Great info Steve. I'm goign to have to do this when i clean my engine bay next week. Got a part number for the gasket. Oh and will Carb Cleaner suffice?
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 01-28-2004, 10:31 AM   #3 (permalink)
No, I found regular carb cleaner (like Gumout) was not strong enough to clean it properly. That's why I mentioned bringing it to a shop to have it cleaned. There is one product called Hydroseal that does a great job. It's put out by Gunk. I don't think it's sold anymore...too costly for the EPA fees. Professional shops may still use it.
IAC gasket: 22271-74022
About $1.75USD at Toyota.
BTW, I also replaced the throttle body gasket since I had it off:
TB gasket: 22215-74400
About $4.00USD
Steve
Old 01-30-2004, 11:11 AM   #4 (permalink)
View Deep's Photo Gallery
I'll give it a shot when it warms up, good post.
Deep is offline   Reply With Quote
Old 09-02-2004, 05:45 PM   #5 (permalink)
bump
