CT26 Wastegate flex pipes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 02-02-2004, 11:31 AM   #1 (permalink)
View Nico's Photo Gallery
Hello everyone,
I know my question might seem a bit dumb but is anyone here able to tell me where (from/to) go the flex pipes on the ct 26 turbo wastegate. I am not sure to understand...
Thank you for your help !
Nico
Nico is offline   Reply With Quote
Old 02-02-2004, 04:48 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Flex pipes?
You talking about the vacuum hose from the wastegate actuator to the compressor housing?
"Skoolin' the unlearned!"
Old 02-02-2004, 05:26 PM   #3 (permalink)
Yes exactly ! It seems there is one going from the wastegate actuator to the compressor housing and another one leaving the wastegate actuator to go to where ?
Nico
Old 02-02-2004, 05:33 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
You have a dual port actuator.
I believe the other port on the wastegate goes to a VSV. You can probably cap it off and leave it alone.
Is the turbo from a 3S-GTE?
Old 02-02-2004, 05:37 PM   #5 (permalink)
Yes it's coming from a 3sgte. So you 'd just leave it alone ? (That's what I was about to do in fact) Thank you 88 le !
Nico
Old 02-02-2004, 05:51 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
Yeah I'd leave it alone.
Place a vacuum hose cap over it and use a small hose clamp to secure it so that it doesn't pop off.
Old 02-02-2004, 06:18 PM   #7 (permalink)
Thank you !
Nico
Old 02-02-2004, 07:14 PM   #8 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $302875
Caping it or leaving it open will give you different boost responses... hopefully you pick the right option!
-Charlie
Old 02-02-2004, 08:27 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Just wanted to clarify something.
You cap off one of the ports on the actuator and leave the other one connected (actuator to compressor housing).
If you don't have a hose going from the actuator to the compressor housing the wastegate will never open. You'll overboost and possibly destroy the turbo from overspinning it.
Old 02-02-2004, 08:32 PM   #10 (permalink)
Trailer Trash Engineer
alltrac165's Avatar
View alltrac165's Photo Gallery
^ Ditto what 88LE said. ^
Both bibs go to the same chamber so if you leave one open, no pressure can build in the actuator to open the wastegate. You must plug the one that doesn't go to the compressor. Or you could put a boost controller on it, I suppose.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
alltrac165 is offline   Reply With Quote
Old 02-03-2004, 02:29 AM   #11 (permalink)
ok thank you guys !
Nico
Old 02-03-2004, 05:06 PM   #12 (permalink)
white90dx's Avatar
Heh... I should let the guys that know the CT-26 wastegate actuator talk.
I have an extra actuator for my T3 that has two ports on it - on is on each side of the diaphram (ie, pull on the actuator arm, air goes in one and out the other).
I'm hoping that its a lower spring pressure than the one that is on there currently so that I don't overboost like somebody else I know... *cough*88LE*cough*
-Charlie
Old 02-03-2004, 05:39 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
Weird. I've never seen a actuator with a port on each side of the diaphram.
The dual port actuator that we're talking about above has 2 ports on the top half of the diaphram.
Haha...
I was going to buy a external wastegate (HKS standard) and modify the adapter for it. But I melted a piston before I got around to it.
