TRD race engine - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 06-29-2009, 12:08 AM   #1 (permalink)
View turnleft's Photo Gallery
TRD race engine
Ok so here's the deal. I race dirt oval and always try to be an innovator. So i got to thinkin "if nascar can run toyota and woop up.....why not try?" So i guess my question is can you build a TRD engine under these rules that put out numbers like my chev (600hp and 620 ft lbs of torque)
24. ENGINE SPECIFICATIONS: Any American make steel engine block allowed. Aftermarket and OEM performance blocks allowed. Steel heads and oil pan only. Flat tappet cam/lifters and stud-mounted rocker arms only. No stud girdles. No mushroom lifters, lifter diameter and configuration must match OEM passenger block. OEM firing order cannot be changed. No crank triggers. All engines must be able to be used in conventional passenger car without alterations. Engine mounts cannot be removed or altered. Castings and fittings must not be changed. No machine work on outside of engine. All belt driven accessories must be on front of engine. ‘Wet’ sump oiling system only
If so....could you steer me towards a place to get parts etc? or possibly an engine builder that would do it?
Thanks-Joe
turnleft is offline   Reply With Quote
Old 06-29-2009, 05:50 PM   #2 (permalink)
wtftoy's Avatar
View wtftoy's Photo Gallery
Holler at Tony the Tiger , trd4life, and/or ASG14. Those guys can help you, sorry if I miss anyone, there are more people that build engines, but I just did a quick search on the threads I been reading.
1998CamryLEV6
Tokicos,Eibachs,TrdRSB,Intake,Jim'sTorqueRod.
wtftoy is offline   Reply With Quote
