transmission pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 02-09-2004, 12:27 PM   #1 (permalink)
Banned
View |PuNiSh3R|'s Photo Gallery
This isn't exactly hardcore super tech veteran info.. but I needed a fast answer
If I do believe correct, when the car is started on an automatic transmission vehicle, there is ALWAYS pressure on the fluid, right?
So if I started my car and I measured the pressure at the tranny cooler I've installed.. what would it be? I guess it gains pressure as the rpm's increase, right?
Reason I ask is because I need to install this oil pressure switch somewhere and on the block isn't an option.. it's a pressure switch for a GM vehicle.. so it has the leads on it that I need to connect the wiring for my electric fuel pump... I did a mechanical to electronic pump conversion on my 4af engine and now I need a way to turn the pump on when the engine is running and off when the engine stops.. so I figured that the tranny might be a good place because it would be easy to tap into since I have a tranny cooler on it already..
|PuNiSh3R| is offline   Reply With Quote
Old 02-09-2004, 07:12 PM   #2 (permalink)
Trailer Trash Engineer
alltrac165's Avatar
View alltrac165's Photo Gallery
I'm not sure of the operating pressure in the tranny, but it might not reach a pressure high enough to trigger the switch when you are cranking the engine. I think you're going to have to use engine oil pressure as that can reach a decent pressure under cranking in order to start the fuel pump. Just a guess, though, don't know for sure.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
alltrac165 is offline   Reply With Quote
Old 02-10-2004, 04:19 PM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279392
View csaxon's Photo Gallery
With transmission in D position and fluid at 122-176 degrees F
A140E idle 53-61psi Driving 107-125psi Reverse 90-115psi
A541A 58-66psi 165-179psi 117-128psi
Both transmissions have test plugs on lower front sides that could be adapted.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
