1986 Corolla Hesitates when coasting in gear
Hi There,
>by chugging.......do you mean rough idle.........or.......is it more
>like.....extremely low rpms?
No, what happens is that the whole car shudders when coasting in gear. (ie no pressure on the gas pedal while coasting in gear up to a light.)
I figured at first that it might be a valve problem, so I did a compression test. That is how I found the burnt valve in the number 1 cylinder. While installing a rebuilt cylinder head, I discovered fuel in one of the vacuum lines coming off the carb, and I traced the source back to the auxiliary accelerator pump. While doing that, I also discovered that the idle cutoff switch for the emmisions control system wasn't rigged properly and that the switch wasn't working, so I fixed that too.
You'd think all of that would have had some effect, but it didn't so I kept looking. I subsequently found that the diaphragm on the vacuum advance system on the distributor had a hole in it and that the distributor cap and rotor were pitted, so I replaced those this past week.
Admittedly, car does run a lot better now than when I first got it, and I'm still happy with it (I refer to it as "my old dog". It has it's personality quirks, yet I take care of it and it takes care of me...) I'd just like to figure out what the source of the shuddering is. (For the record, the shuddering stops as soon as I press the clutch or take it out of gear, and it only happens when there's no pressure on the gas.)
Kevin
