3sgte vs. 5sfe transmissions - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 02-12-2004, 11:33 PM   #1 (permalink)
Vosier Autosport
View carheadz's Photo Gallery
I'm about to do a swap on my ride. Is it better to keep the 5sfe transmission or just use the 3sgte transmission? Which transmission has a shorter gear ratio for a quick take off? does anybody know the gear ratios for the both of them and if a 5sfe transmission will bolt right on to the 2nd or 3rd gen 3sgte engine. Thanks.
carheadz is offline   Reply With Quote
Old 02-12-2004, 11:46 PM   #2 (permalink)
In Ur MOM's Pants
RedruM's Avatar
View RedruM's Photo Gallery
make your own transmisson with homemade gears out of coke cans and duct tape
zip tie it to the motor.. trust guy this is the way for maximum power
keep the signatures clean please
RedruM is offline   Reply With Quote
Old 02-13-2004, 01:51 AM   #3 (permalink)
S14 Fever :D
Rapeacivic's Avatar
View Rapeacivic's Photo Gallery
From what I've read using the search button, it's better to use the E-153 tranny from a Solara when doing the 3SGTE swap on a 3rd gen Camry.
Originally Posted by LynchburgCSI View Post
Ladies and gentlemen... the only turbo 5s-fe camry still in existence. Welcome back Terry. I can't wait to see how this goes.
Rapeacivic is offline   Reply With Quote
Old 02-13-2004, 08:06 AM   #4 (permalink)
Vosier Autosport
I'm guessing that it would come out of the V6 Camry/Solara? Do all the 92+ V6 Camry and the Solara trannies just bolt on then? Is the transmission stronger or the gear ratios are shorter than the stock 5sfe or 3sgte? Thanks.
haha . Zip Ties will do the job brotha...
Old 02-14-2004, 10:32 AM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
both the solara V6, camry V6, and the MR2 turbo have the same tranny code E153. The difference is the final drive (camry/solara V6 3.98 vs MR2 turbo 4.29)and the gear ratios are a 10th off each other.
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 02-14-2004, 04:54 PM   #6 (permalink)
Vosier Autosport
So would the Camry/Solara be a better option?
Old 02-15-2004, 08:52 PM   #7 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
Um personnally if you plan on using your car for more of daily driving and hwy cruising ... I suggest going with the solara/camry tranny. Plus you would have to modify the hell out of the MR2 trans to convert it from rwd to fwd... I mean by rwd is the shift linkage are facing the front of the vehicle while the solara/camry v6 trans are facing the rear of the vehicle...
MySpace:
Old 02-18-2004, 06:42 PM   #8 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $303475
Does the MR2 tranny otherwise bolt up? (I'm worried about a gen2, not gen3 Camry) Rather than changing the tranny, could the control cables be lengthened to go around the front of the motor? My gut tells me its not that simple, but I wanted to at least get an experienced opinion on it...
Thanks,
Charlie
Old 02-18-2004, 08:31 PM   #9 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
Thanks,
Charlie
theres a link on how to convert the MR2 tranny into fwd shift linkage... I think that way is the best ... Its on the camry forum on ToyotaNation... I did it the hard way were I actually swapped out the whole tranny housing from 3 different cars...
MySpace:
Old 02-18-2004, 08:40 PM   #10 (permalink)
white90dx's Avatar
Ouch, yeah. I have that link on changing the linkages. Then I just have to find a cheap way to get the parts off a FWD/AWD tranny. Its too bad the ones off my current tranny won't work.
I just can't help but think that for a couple thousand dollars for an MR2 rear clip I could have all the (current) issues of my Camry solved and have a nice motor and tranny to go with it. Then again, there would be wiring issues, since its not a plug-and-play deal...
-Charlie
Old 02-18-2004, 11:10 PM   #11 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
yep this was the problem i was facing. Try and ghetto rig something, or not.... Thats when i decided on the 3SGE. cheaper, 170hp, and its FWD and available with automatic if interested. Im getting mine for $735 w/shipping. That gets me the motor, trans, harness, ecu, ignitor, and MAF. cant beat that.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 02-19-2004, 05:58 PM   #12 (permalink)
N/A bites
Tercel GTS's Avatar
Well I'll be tackling this same issue in a week or so as I convert my MR2 trans to FWD. Watch for pics in the Tercel forum under replacement project car.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
