Coolant mixed in Trans fluid! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 08-11-2009, 08:06 PM   #1 (permalink)
Blessed Driver!
Revival's Avatar
View Revival's Photo Gallery
I think I know the answer to this one already but wanted to get a sanity check. Ex Toyota Pro tech here, but 15 years out of the business. I have forgotten much.
Vehicle: 1999 4Runner Limited 4WD, Auto transmission, 160,000 mi.
I was on a short trip to the store when I noticed the trans shifting hard. Within just a few minutes I overheated and pulled over to find transmission fluid and coolant pouring from the top of the transmission. The radiator was empty and when filled, there is trans fluid there also.
Expectation: The trans cooler lines have failed within the radiator. The overheating caused the coolant pressure to force coolant back into the trans. Sound right?
My plan unless someone has any other recommendations:
1) Replace the radiator and flush thoroughly.
2) Drain and refill transmission. Immediately take to trans shop for full flush and filter change in hopes of saving transmission.
Please voice your opinions. I need to drive this truck a bit longer if possible but will consider a trade in if you think I'm headed for a new transmission regardless of what I do.
http://www.jermanbuck.com/images/revival_tell_sig.gif
Revival is offline   Reply With Quote
Old 08-12-2009, 08:22 AM   #2 (permalink)
Blessed Driver!
Revival's Avatar
Does a MOD want to move this to the 4Runner section? lots of "0" replies here... Just looking for active Technicians to give me a sanity check that I am on the right path.
Old 08-14-2009, 11:02 AM   #3 (permalink)
Gameroom cash: $147537
I agree with you. There is no other way to get coolant in tranny. Unless someone fill it with coolant
Old 08-14-2009, 11:25 AM   #4 (permalink)
View titleist's Photo Gallery
this is very common with four runners. replace the rad and flush the fluids until the "pepto bismol" is gone.
titleist is offline   Reply With Quote
Old 08-15-2009, 08:56 PM   #5 (permalink)
Blessed Driver!
Revival's Avatar
Thanks,
Still in a bit of the "pepto" phase but only very minor. And also chasing trans fluid out of the cooling system. On the last test drive it is shifting a tad hard from 1st to 2nd, but otherwise good. I will change the trans fluid a few more times.
Old 08-21-2009, 08:16 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235245
View speedy25's Photo Gallery
Be sure to flush your engine too. Oil makes a great insulator in a water cooled system and your cooling efficiency will be poor until you get all the oil flushed out.
-SP
