AE92 no spark problem - HELP !! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 02-22-2004, 06:31 AM   #1 (permalink)
View dwake122's Photo Gallery
Looking for some help and/or ideas
1990 Corrola GTS
Stalled car at lights on morning and she hasn't started since
I've checked wiring, fuses, etc., and replaced the coil and igniter (new OEM @ $500).
Still no spark from coil !
Any suggestions ?
On limited budget so more expense at a garage is a last resort
Thanks
dwake122 is offline   Reply With Quote
Old 02-23-2004, 08:11 PM   #2 (permalink)
View 20vstarlet's Photo Gallery
Had a no spark issue with my 4afe. Copper windings down around the shaft came apart, I replaced the whole dist. with a junkyard piece.
20vstarlet is offline   Reply With Quote
Old 02-24-2004, 12:32 AM   #3 (permalink)
operation boro thunder
View project trueno's Photo Gallery
sometimes getting your car checked at a shop is cheaper, than guessing on your own and buying parts from dealership brandnew
it seems like the pick-up coil/signal generator assembly is faulty (inside your dizzy), try to simulate the signal action with your battery, pulse it on and off (connect to battery then disconnect) and you should see a spark, if you do grab another distributer from wreckers
project trueno is offline   Reply With Quote
Old 03-10-2004, 09:57 AM   #4 (permalink)
Unhappy no spark update
Ok here we go
Have now replaced igniter, coil and installed a replacement distributor ( which I know is working )
I have power @ the coil , igniter, injectors, all grounds have been checked and cleaned. All wiring from dizzy has been checked for continuity.
There is fuel pressure. Timing belt OK
Everything seems to be Ok but still no spark !!
Any other ideas
The car is currently with my mechanic and even he is stumped so far
Old 03-10-2004, 05:29 PM   #5 (permalink)
Wash it with gas and dry it with a match
Old 03-11-2004, 02:05 PM   #6 (permalink)
Did think of that. High octane for best results ????
Going to try brain transplant first.
