3ZV-FE oil pressure specs? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 02-25-2004, 08:04 AM   #1 (permalink)
View JohnStra's Photo Gallery
Where can I find OEM oil pressure specs for my 3ZV-FE? At low idle (750), my oem guage shows NO oil pressure (with a new sender). My mech dash guage shows ~18psi. Does this with both 5w30 dino or 0w30 Amsoil. All other temps (RPMs) seem ok, but I'd like to test with mech guage against specs.
JohnStra is offline   Reply With Quote
Old 02-26-2004, 03:51 AM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
OEM specs...
at idle, 29kPa, 4.3psi or more
at 3,000rpm, 294-539kPa, 43-78psi
i hope you are doing the readings with a pressure gauge connected to where the oil pressure switch screws in, right next to the oil filter. ya know i think i have a pic of this...
yup i had it attached to an old thread...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 03-01-2004, 08:22 PM   #3 (permalink)
From service manual?
Zoni - Did you get those pressure specs from the service manual? If so, I trust them over what my Haynes says...
4.3 psi @ idle
36-71 psi @ 3000 rpm
Old 03-01-2004, 08:36 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
yeah straight from the toyota service manual.
Dave Zoni
Old 03-02-2004, 07:31 AM   #5 (permalink)
CTM/ShiftGate CAMRY
racerhex's Avatar
View racerhex's Photo Gallery
That oil pressure switch what exactly does that do.......and can I hook my oil pressure gague up to it or what.....sounds noobish i know but im not quite sure! LoL
3vz-fe w/ all the good stuff
Does My Wiper Offend You? Look Ma no handles!
www.ctmotorsport.com FOR ALL YOUR CAMRY NEEDS
http://members.cardomain.com/racerhex<----CHECK ME OUT...UPDATED!!!!
racerhex is offline   Reply With Quote
Old 03-02-2004, 07:59 AM   #6 (permalink)
On many vehicles, the oem oil pressure guage/switch is little more than a dummy light - it generally tells you if there's a problem, but it doesn't give you much real time info. The oem switch is installed in a port. You can install your own sender in the port for your guage. Some vehicles ECM requires that the oem switch remain installed though, so you may have to T off the port.
-john
Old 03-02-2004, 09:52 AM   #7 (permalink)
CTM/ShiftGate CAMRY
racerhex's Avatar
thanks ill look into that!
Old 03-02-2004, 01:09 PM   #8 (permalink)
I'm a Mac
zoni's Avatar
thats exactly what people do when they need to hook up a gauge, nice johnstra!
Dave Zoni
