93 Corolla with electrical gremlins - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 02-28-2004, 11:22 AM   #1 (permalink)
View brian_g's Photo Gallery
Question 93 Corolla with electrical gremlins
My 93 Toyota Corolla (1.8L, auto, 120k miles) suddenly developed a series of electrical woes. The check engine light flashes about once per drive. The error codes are the "ignition signal" (ignitor, ignition coil, ECM), "coolant temperature" (coolant temp sensor or ECM), and "knock sensor signal" (knock sensor or ECM).
The airbag light is also on but I suspect this is unrelated. The car has a fresh set of Bosch platinum spark plugs, ignition wires, dist. cap, and rotor.
Is it possible for all 3 of these parts (ignition stuff + 2 sensors) to good bad all together or is the ECM a problem? Any thoughts?
On edit: the idle while driving is too low - when my foot's off the gas the RPMs seem to drop too low. No tach no no numbers
brian_g is offline   Reply With Quote
Old 03-01-2004, 02:59 PM   #2 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Moved to tech section...
Chris Corolla S is offline   Reply With Quote
