Engine boring and honing - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-02-2004, 12:15 AM   #1 (permalink)
Banned
View |PuNiSh3R|'s Photo Gallery
I have to rebuild my 4AF because the oil smells of gas, I am now burning oil.. I've had thin oil in the past, I always did change the oil every 3K.. I did a comp check.. things didn't check out to well.. and I get horrible gas mileage.. as in 160mpt..
My question is, will I NEED to have the cylinders over-bored or will I be ok honing the cylinders myself? I'd like to do anything I can to keep away from over-boring.
|PuNiSh3R| is offline   Reply With Quote
Old 03-02-2004, 11:23 PM   #2 (permalink)
camrys blow off too!
View silverstreakin's Photo Gallery
once you take it to a machine shop, they can tell you if you have taper wear or anything else that would require oversize. going ten thousandths over isnt a big deal, you dont sacrifice much on that , and usually, you dont need new pistions. your question on if you will need, you WILL need to have it checked by a professional
93 toyota mark II tourer V
1jz-gte twin turbo goodness!
93 toyota scepter turbo stored back in the states!
*in loving memory rapeacivic*
silverstreakin is offline   Reply With Quote
