89 tercel valve adjustment - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-06-2004, 08:49 PM   #1 (permalink)
View scotty's Photo Gallery
Question 89 tercel valve adjustment
I tried to adjust the valves on my 89 tercel 3e engine but could not get even get my feeler guage (standard blade type) to slip between the valve and rocker. I was going by a chiltons manual--wich shows a different engine 8 valve--mine is 12. My engine has rocker springs the one in the manual does'nt. I've done this on a 22r motor before with no problems...what is the trick to adjusting the valves on this engine? I tried to slide the guage under both side of the rocker, but it get in there--and yes the engine is at tdc 1 and rockers are loose. Would love some help!
scotty is offline   Reply With Quote
Old 03-11-2005, 11:54 AM   #2 (permalink)
View rstep1's Photo Gallery
Did anyone answer your question?
Richard
rstep1 is offline   Reply With Quote
Old 03-11-2005, 06:42 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
if it aint skipping at idle, ya better leave em alone, this motor has enough trouble climbing hills without you making the valve lift any less, what are you wanting to set them at?
Old 03-31-2008, 11:31 AM   #4 (permalink)
View burtonridr's Photo Gallery
Bump
I'm having the same freakin problem!
Here is why you cant slip a feeler gauge in there. The rocker arm has a horse shoe shaped tip that sits around the valve. WTF!
I dont know how you are supposed to adjust them. I was hoping to find a wire feeler gauge that fits between the rocker arm and the valve.
I think I'm going to take my dremel to my feeler gauge and cut it so that it will fit in the horse shoe shape.
Anyone else know anything about this problem?
1987 Toyota Tercel
Mmmm...Gourmet Coffee
burtonridr is offline   Reply With Quote
Old 09-12-2008, 01:58 PM   #5 (permalink)
View igonuts2's Photo Gallery
gauge between the cam and the rocker arm. make sure a .009 wont fit but a .008 will. you b fine. if you here the tapping come back, you didnt tighten the locking nut enough.
92 pu 4x4 V6 5sp 3'' lift
89 tercel 3dr 3e 5sp
'56 willys pu 4x4 "rat". under destruction. i'm in heaven!!!!!!!
igonuts2 is offline   Reply With Quote
