Help!! Oil Shooting Out Of Distributor - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 01-24-2010, 08:19 PM   #1 (permalink)
View 94sleeper's Photo Gallery
Help I need some help bad 94 Camry 5SFe (california emmisions)
the title says it all. did the heads got rebuilt block,
runs great starts everytime...but major oil leak coming out of distributor.
Replaced the o-ring on distributor seems it was brittle and cracked when touched. No leak at first took it out on highway and seems like the leak is worse. drips at idle shoots in a stream whe reved up and pressure is on called dealer parts counter to ask if there is a seal they said o-ring told them I replaced it, they said distributor is bad, Is that right?
$517 @ dealer
is junk yard distributor ok?
new or remanufactured $50 difference @ NAPA $250-299
if no to junkyard is reman ok or go with new money is tight but i want to do it right... if this is the problem
Thanks
94sleeper is offline   Reply With Quote
Old 01-25-2010, 07:44 AM   #2 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
Are you certain you installed the correct size o-seal, the distributer has no play when inserted properly into the exhaust cam and that the u-clamp and valve cover are torqued down properly?
If all these things are okay, maybe you can try using a slightly oversized o-seal. Get your hands on a vernier caliper and do some measuring.
Hope this helps.
Hook is offline   Reply With Quote
The Following User Says Thank You to Hook For This Useful Post:
94sleeper (01-25-2010)
Old 01-25-2010, 01:05 PM   #3 (permalink)
thanks
yes its the right o-ring was the same size as the one that came off. Everything is tourqed down
valve covers arey dry the oil is coming from behind the distributor and it is in and seated the engine runs great
just shoots oil the distributor is tight I will check it and be sure Thanks
Old 01-25-2010, 01:06 PM   #4 (permalink)
U clamp?
what U clamp I don't see no u-clamp
Old 01-26-2010, 11:25 AM   #5 (permalink)
Hook's Avatar
When the valve cover's off, the hole that the distributor comes through to connect to the exhaust cam is actually made up of a semi-circular cut out on the head itself and the top part is a sort of u-clamp with a corresponding semi-circular cut out, which when clamped makes the circular hole you see there. Most times it's not intefered with when replacing a distributor, but in case it was, it would help to ensure it was torqued properly.
Question though, did you buy it loose from an o-ring seal kit, or was it a factory seal from the firm specifically for the distributor?
The reason I ask, is that u must bear in mind that the old o-seal that came off the dizzy would be hard and shrunken (likely also flat) with age. So buying one the exact same size would mean that it's still not making a proper seal, as opposed to buying a slightly larger one, or even better, the specific seal for that application from the dealership.
I'd a similar problem with oil leaking from the VVT solenoid on a 20V. The old seal was brittle and shrunken and flat and simply flaked off when I tried to remove it. So, I put the pieces back together and found a very very slightly thicker o-seal with the same inner diameter from a seal kit and it worked. Took a thin coat of oil to get it back in, but it hasn't leaked since.
Oh, and ensure that the o-seal u replaced is seated properly in the groove and hasn't folded out when u put the distributor back in. If it has folded, replace the seal (as it's now damaged) and try again.
