thermostat temperature? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-11-2004, 02:51 AM   #1 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
Question thermostat temperature?
i've been thinking about this today, which would be desireble and in which situations?
cold may give lower overall engine bay temps, but the engine may be more efficient at higher temps
-Nick
Nick is offline   Reply With Quote
Old 03-11-2004, 10:55 AM   #2 (permalink)
Nick's Avatar
ok, i think i got it straight, if ppl add water wetter to cool down even more then at least for track the lowest temp possible is desired
-Nick
Old 03-11-2004, 11:09 PM   #3 (permalink)
View warlock's Photo Gallery
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 03-12-2004, 06:14 AM   #4 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
I guess what I would like to know is how much extra cooling will the water wetter and/or thermostat provide. Like if you bump the temps down out of the efficient range, isn't the ecu going to think it still needs to run in warmp-up mode and compensate by adjusting timing and gas and such?
Or is the deal that it'll just run at the lower end of the correct temperature range or not heat up as much when you push it?
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 03-12-2004, 11:08 AM   #5 (permalink)
water wetter cools temp down a little, buy lowering the temp the ECU wont keep the car in warmup,warmup shuts down at a pritty low temp,and your thermostate regulates your temp
94 Scepter 1MZ-FE
