engine won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-11-2004, 10:35 PM   #1 (permalink)
View SurlySteve's Photo Gallery
engine won't start
I'm having a problem. My car is a 1990 toyota tercel with a 1.5l carbed motor. The engine cranks over but won't start. sometimes it sputters and sounds like it will start while cranking but doesn't start. It's getting fuel and there is spark. Any ideas would be greatly appreciated. Thanx.
SurlySteve is offline   Reply With Quote
Old 03-12-2004, 04:43 PM   #2 (permalink)
View onephatcracka's Photo Gallery
i'd check your pressures....... you may be getting fuel , but are you getting enough?..... also check your vaccum lines. sometimes that could cause it. Take off your air filter and cover around the carb and see whats going on. Your carb may be clogged too. It's hard to tell what could be wrong from here, but i would check and double check those things.
85 supra
O.A.F.
stock
onephatcracka is offline   Reply With Quote
Old 03-12-2004, 06:53 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
Is it spinning really fast? If so timing may have jumped. If not do this, take the cap off the distributor and look inside for a small capacitor. Does it appear melted? If so go to the dealer and buy a new capacitor. This is a common problem on that era of Toyota, in fact we did a few last week at the shop.
There are several things really that it could be. Start with the three basic needs, fuel, spark, compression. Good luck and keep us posted.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-13-2004, 06:31 PM   #4 (permalink)
hey thanx for the ideas guys. I'll look into it
