Transmission swap question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-16-2004, 06:09 PM   #1 (permalink)
N/A bites
Tercel GTS's Avatar
Does anybody know if an e153 V6 5speed will fit to the same mounting brackets and locations on a car that came with a 5SFE?
Not asking if it will bolt to engine nor the end mount by the wheel. My reason for this question is trying to install an MR2 tranny to a fwd car and using the cross bar underneath from a celica. The hole is about 1" off. I realise this is no big deal and can just drill the hole. But if a factory bracket can fit and fix the problem I'd like that option.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 03-18-2004, 01:28 PM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
use a bracket from a 92-93 v6 std camry or 97-01 camry v6 std. its called the tranny mount... it might mount up to the same holes as in a celica. BUT using the rwd tranny in the fwd car, that means the linkage is on the front side, so you either have to find longer shifter cables or move the linkage or just get the camry/solara e153 tranny.
but if it is just a matter of drilling a hole, i'd say do that...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 03-18-2004, 06:19 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
The linkage issue has already been covered, I bought a lexus tranny to source the conversion parts from. The tranny repair guy I know says I can swap 5th gear from the Lexus tranny to the MR2's and according to posts on this board the Lexus has a different ratio in 5th. Of course I'll count the gears when doing this to confirm as a benefit or not.
雄のハヤブサ
Old 03-18-2004, 07:12 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
cool then, sounds like you got a plan...
you can see what the tranny mounts look like here...
http://www.midnightdreams.org/res/pix/mounts.jpg
Dave Zoni
Old 03-19-2004, 06:56 AM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
Nice pic. I've been trying to find one like that of a 93 Celica GT with 5SFE and 5speed. That'd be more how my mounting system looks.
雄のハヤブサ
