what is the point of a cai when the air heats up in the tube when it reaches your engine bay? i thought alot about this and came to a briliant (correct me if i'm wrong)conclusion...use the air conditioning.
every one has heard of air to water intercoolers and air to air but they are limited in efficiency you add weight with water and soon i gets just as hot the other sometimes the outside temp is hotter than you like sure you can use sprayers but soon you need to refill, am i right?
so i thought and walked around my house,garage,and yard when i saw the ac unit and got an idea
(you guys are hating the fact that i'm carrying on huh?)
if you wrap the pipe in aluminum tubing tightly and put a couple of coils of tubing in front of the evaporator fill the tube with deicer washer fluid using a small resivoir and a pump to move the water through the system make sure there is no air in the system hook it to the ac switch that way when you turn on the ac both systems will work together to reduce the air temp more efficiently and constantly without freezing the line.
it will take time to do it but it will be worth it.
i'll get my freind to let me use his camera so i can post pics so you can get the idea
this wont work for those of you who decided not to fix your ac or the ones who decided the turbo needed more room
