acceleration problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-28-2004, 03:30 PM   #1 (permalink)
View onephatcracka's Photo Gallery
I have a 1985 celicasupra and when I first start to drive it when i start it up i have a problem. When i push the "pedal to the metal" it seems to jult while accelerating. I have gotten the injectors cleaned and i have replaced the fuel filter. I also took the entire intake house off (thinking there may have been a clog) and cleaned it out. I currently have oil leaks through a few of the seals (mostly the rear main seal), but i didn't think that would have any effect on that. Also, I was wondering if there are any common problems with the 5ME engine in the past or any someone has come across.
85 supra
O.A.F.
stock
onephatcracka is offline   Reply With Quote
Old 03-29-2004, 02:39 PM   #2 (permalink)
85 supra
O.A.F.
stock
Old 03-29-2004, 03:37 PM   #3 (permalink)
View DIRTBIKEZ's Photo Gallery
One problem is that you are putting the "pedal to the metal" before your car has gotten a chance to warm up .
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 03-29-2004, 08:29 PM   #4 (permalink)
ha i didn't mean i just start and take off... i let it warmup till the engine drops in rpm's.... then i got and it does this... my mistake if i didn't explain
85 supra
O.A.F.
stock
Old 04-03-2004, 12:30 AM   #5 (permalink)
dark angel of death
View americanjebus's Photo Gallery
does the engine jolt or ur whole car??
3'' cooleze downpipe w/ oversized turbo elbow
K&N FIPK
soon to come bosch110 bov.
1992 supra turbo
americanjebus is offline   Reply With Quote
Old 04-03-2004, 01:31 AM   #6 (permalink)
the car kinda jolts... like when i hold down on the gas it seems like it loses power and then all of a sudden it gains it
85 supra
O.A.F.
stock
Old 04-03-2004, 02:54 AM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Might be a broken engine/transmission mount.
Old 04-03-2004, 09:20 AM   #8 (permalink)
View Morpheus's Photo Gallery
How can you tell if the engien or whole car is jolting?
It happens with my Corolla a little bit, it kind of stutters when floored for a split second. I think it might be bad timing because it diesels too when I turn it off.
Morpheus is offline   Reply With Quote
Old 04-03-2004, 05:54 PM   #9 (permalink)
damn.... i hope it isn't an engine or tranny mount..... it doesn't do it though when it's warmed up..... if it was the mount wouldn't it happen all the time?... i'm not sure if it's the timing becaue my car doesn't diesel at all
85 supra
O.A.F.
stock
Old 04-05-2004, 02:43 AM   #10 (permalink)
dark angel of death
probably just flooding ur engine, if it doesnt do it while warm its just ur oil is pretty thick, its flooding, or just not gettin enough incoming air.
K&N FIPK
1992 supra turbo
Old 04-05-2004, 08:17 PM   #11 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
So do you let the car warm up or not man
Maybe your oil pressure takes a while to come up?
Chris Corolla S is offline   Reply With Quote
Old 04-05-2004, 10:10 PM   #12 (permalink)
Blane's Avatar
View Blane's Photo Gallery
You guys
His car hesitates when he accelerates.
The engine is carborated.
I think the answer is for him to clean his carborater.
A good mod to help those engines is a ignition system (MSD).
Yay let's get em fuel a burn'n.
Blane is offline   Reply With Quote
Old 04-06-2004, 02:41 AM   #13 (permalink)
nahh the engine is EFI.... did any 85's come carburated?...... and it's possible i guess it could be the oil... i mean the pressure stays low because the rear main seal is leaking pretty bad(which i am replacing as soon as i get off for the summer from college)
85 supra
O.A.F.
stock
Old 04-08-2004, 07:55 AM   #14 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
My dad's old '83 was EFI so I'd inagine the '85 is too... this is the 5MGE? Not too familiar with old-school Supras... as far as loss in power is oncerned see if your rubber intake tube is cracked. Sounds dumb but this happened on my aunt's '86 Celica GT-S a while back and the thing lied flat on its face. Bucked and jolted a little too.
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 06-24-2004, 01:54 AM   #15 (permalink)
View rollafan's Photo Gallery
if ur engine is carbd the prob would be being caused by ur air intake, as the airflow through the carb is small to start with it won't suck fuel through at first, causing ur loss of power, try a k&n high flow intake. If it's injected u should get ur fuel pump and lines serviced as in this age vehicle is likely, it could also be caused by dirt in the tank, while its idling the dirt would be sitting in the bottom of the tank then as fuel flow increases a lump of dirt ie a flake of rust/paint would get sucked over the intake pipe and restrict the flow of fuel, also try just replacing the air filter may help.
rollafan is offline   Reply With Quote
