Need Help On AXel for 98 camry - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 03-29-2004, 10:14 PM   #1 (permalink)
View magic651's Photo Gallery
Smile Need Help On AXel for 98 camry
I have no where to get information on how to take out the passenger side axel on a 98 toyota camry 4 cy. I have taken off all the bolts and clips and have tried for hours to get the axel out because it is no good but it would not move, any help pictures or website, i need help. I have the new axel already and need to put it in!
magic651 is offline   Reply With Quote
Old 03-29-2004, 10:19 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You need to use a crowbar and pry the axle out of the differential. Its a bitch, but it'll come out.
Make sure you remove the bolt and snap ring from the center bearing carrier.
"Skoolin' the unlearned!"
Old 03-29-2004, 10:28 PM   #3 (permalink)
where should i be prying it from
I have been trying to get it out this evening seems like the axel goes through a mount, should i be prying it from where it goes into the tranny or should i pry it from the mount?
Old 03-29-2004, 10:39 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
The mount is the center bearing carrier.
You want to pry on the axle where in goes into the tranny. Technically its the differential, but whatever.
