Supra radiator removal: see the 2 bolts and the little clips that go from the rad support member over the rad at the corners? Remove them. Take the hoses off, and unplug the electric aux fan. Pull the whole thing out the top. Quite easy. Unbolt all components (5 bolts and all are 10mm everything). Bolt to a new rad and slide it back in reverse to the removal instructions. The rubber feet the rad sits on are easier if you leave them in the car and insert the rad pegs into them when installing. A little push down to get it seated and you're done. Hook up the hoses and plug in the aux fan. You may have to wiggle the clutch fan around a bit if you have trouble getting it back in past it.
To bleed the air out, lift the front of the car as far as possible, fill the rad and start the car. Leave the heat running to clear the heater core. Fill until you see no more air bubbles. We call this burping the baby...takes 20-30 minutes. When complete, cap it, and drive it around some and ensure you don't hear a 'waterfall behind the dash'. If you do, lift and repeat the burping. Keep doing so until you stop hearing it.
BTW, what second drain plug...we only have the one on the rad....????
Bob
