Idle speed is not set by the mixture screw. There should be another screw that goes up against the throttle plate cam either on the same side as the throttle cable or on the opposite end of the shaft. Idle speed can be affected a little by the mixture screw, but that's not how you set it. After you get the speed set, then go back to the idle mixture screw and adjust it back into the carb until you start to lose rpm then back out till the rpms come back. Then you get to start messing with the jets.
Oh yeah, go back over the engine and make sure you don't have any vacuum leaks as this will drive you friggin crazy trying to tune the carb. Be ABSOLUTELY sure you have all the vacuum lines routed properly or capped if they are no longer necessary.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen  ) SOLD
