That depends on how much boost you're running which contributes largely to how warm your intake charge (read: air) is. Also, it matters where your intercooler is mounted and what type it is. You could have a front mount intercooler (FMIC) and run 25psi boost and cool your intake air 100 degrees, or you could run 4psi boost with a top mount intercooler and only cool it a few degrees. There is no guarantee, but the general rule is that the cooler the intake charge, the more power you get due to the more air particles burning. Good Question!
DS
1992 V6 3VZ-FE Camry, 5 speed!
