93 to 90 transmission swap - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 10-26-2010, 11:19 PM   #1 (permalink)
CELICA GTS
Joe_c25's Avatar
View Joe_c25's Photo Gallery
Hi all.... I have a 90 celica gts. The clutch and trans are going on it. So I started looking at getting a clutch on ebay. I noticed that it not only mattered what year the car was made but also the month. I have a parts car 93 celica gts that i wanted to use the trans off that . So two questions Im desperately hoping someone can help me with.
1. Will the transmission from the 93 celica gts bolt right on to my 90 celica gts
2. If I get the clutch should i get one that is listed for fitting on the 93 celica trans or the 90 celica motor.
oh and the two cars have the exact same motors 5FSE as far as i know. have swapped out steering knuckles ect.. and looked at the drive axles and they are the same.
and the 90 celica i want to have running good was made 02/1990 not the same bracket as
from 05/90 as listed with clutches on ebay. the only difference i could think of was the mounting of the pressure plate to flywheel
most the clutches in both brackets listed are same 20 spline and 225mm dia.
Joe_c25 is offline   Reply With Quote
Tags
clutch, transmission swap
