OD is bad for the car -
if you are not driving fast enough.
what happens is that the gearing ratio is negativly set against the engine, increasing load that is upon it.
like you are always lugging the engine.
If you are driving fast enough, OD will only kick in once this speed is reached on an automatic.
if you disable OD on your automatic you will see that at hwy speeds (and only hwy speeds) your tach will read alot higher than normal because your car is missing its 4th and on higher class trannies 5th gear, which is the OD gear.
think about 2 circles,
the engine is the larger one, and the tranny is the smaller one. and they spin together.
now with OD, the smaller wheel is larger, than the engine, hence the engine has to work harder to turn it. for every 1 rotation of the engine wheel, the drive wheel only goes around 3/4 times, for argument sake..
you are always running at a ratio that is lower than that of the engine, like switching gears on a bike. so most of the time you are at a ratio that is lower than that of the engine. but at hwy speeds, since
1. load on the car travelling at 100km/h is much less than say 50 km/h and it takes alot less power to keep it moving at 100km/h (ideal conditions: minimal wind, slope, etc) so OD is an effecient gear that will still allow enough power to keep the car at that speed.
under non-ideal conditions like driving thru the rockies or anywhere where there is long durations of inclines, you will see signs that tell drivers to turn their OD off. This is for that very reason that OD will terminate your engine due to the excess load and strain forced upon it.
Usually at high speeds and compensating ecu trickery, OD has hardly any effect on the engine, since the ECU will control when the od will kick in and it is usually at an rpm that is well withing a decent torque range, and hp level as well.
anytime you would try to agressively pass someone on the hwy your engine will downshift because od is not powerful this way...
ramble ramble..
_________________
Andrew Lee
ae92 Trueno
<font size=-1>[ This Message was edited by: trueno92 on 2002-04-09 22:18 ]</font>
