performing leakdown test - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 12-01-2010, 11:12 AM   #1 (permalink)
View Stock4AG's Photo Gallery
Can someone refresh my memory on how to do a leakdown test?
I have a tester but havn't done one for years.
I remember using a stick or straw to find the highest point of each piston, then thread in the tester. The cams should be at the rounded side of the lobe and valves are more or less closed around that rotation?
Does it matter it is compression or exhaust stroke?
Thanks in advance.
Stock4AG is offline   Reply With Quote
Old 12-10-2010, 07:37 AM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Youtube: Eric the car guy. I think he covers it with the compression test.
'07 Honda Ruckus Big Bore
Old 01-05-2011, 06:45 PM   #3 (permalink)
View RichardDrone's Photo Gallery
I have the instructions from my old Snap-on leak down tester. If you still need them I can scan them and then post. Let me know Richard
RichardDrone is offline   Reply With Quote
Old 04-27-2011, 01:33 AM   #4 (permalink)
View pbr333's Photo Gallery
Low pressure leak-down test most accurate at determining cylinder wear....100% in and ??%
out=amount of wear/leakage. For the track you want around 5%or less(fresh/new) ,but as a DD you can have as much as 28%(high mileage,O/H time).
Just screw your adapter in the spark plug hole, turn engine untill your cams for that cylinder are up(rabbit ears/top dead center), connect tester to air compresser , zero guage ,plug in adapter and read.Guage will read % of leakage.
That's for the single guage tool RichardDrone is refering to.
Also a very valuable tool for diagnosing engines.
pbr
pbr333 is offline   Reply With Quote
