ae101 vs 20v - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-26-2004, 02:58 PM   #1 (permalink)
View Ae86 Azn's Photo Gallery
ae101 vs 20v
whats the diffrence between ae101 and 20v blacktop/silvertop someone plz explaine the diffrence to me thx email @ infested_azn@hotmail.com
Ae86 Azn is offline   Reply With Quote
Old 04-26-2004, 03:31 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
silvertop 165hp, blacktop 175hp
Silvertop revs less, blacktop revs more. Silvertop =heavier internals, blacktop = lighter internals.
Blacktop AE111 Levin (newer)
Silvertop AE101 Levin (older)
Old 04-26-2004, 04:30 PM   #3 (permalink)
MR1
View MR1's Photo Gallery
AFM and Map as well i believe
MR1 is offline   Reply With Quote
Old 04-26-2004, 04:44 PM   #4 (permalink)
View Deep's Photo Gallery
Yep,
Blacktop = MAP
Silvertop = AFM
Deep is offline   Reply With Quote
Old 04-26-2004, 06:43 PM   #5 (permalink)
Angry
so silvertop is ae101 and blacktop is ae111 ?
whats the rpm on both engines im getting so confused
Old 04-26-2004, 06:44 PM   #6 (permalink)
and what MAP and the other one mean
Old 04-26-2004, 07:23 PM   #7 (permalink)
MAP = Manifold Absolute Pressure sensor
AFM = Air Flow Meter
A MAP sensor and AFM do basically the same thing, measure the amount of air going into the engine to help figure out what sort of fuel and spark it needs (along with input from other sensors.) An AFM uses a flapper door to measure air, while a MAP sensor measures the pressure of the intake manifold. AFM's are regarded as being less accurate and restrictive on a tuned motor. MAP is better, unless you plan on staying mostly stock, in which case it doesn't really matter.
Old 04-26-2004, 07:52 PM   #8 (permalink)
aka TRD_roLLa on CC.com
View ractive_roLLa's Photo Gallery
how much does a blacktop go for roughly?
ractive_roLLa is offline   Reply With Quote
Old 04-27-2004, 07:53 PM   #9 (permalink)
4A-GE's Avatar
View 4A-GE's Photo Gallery
i though they rev the same? around 7500rpm?
4A-GE is offline   Reply With Quote
Old 04-28-2004, 03:06 PM   #10 (permalink)
View micro214_kp61's Photo Gallery
slivertop cuts off at 7200rpm while blacktop is at 7400rpm
ractive_roLLa.... a full engine swap goes for around $3500. that's with an uncut harness, ecu, 6-speed tranny, etc. you can get a cheap one from Tiger Auto for $1000 but you have to locate your own harness which is harder than locating a whole motor.
ADDED INFO: the most significant difference between the 2 when it comes to performance (stock vs. stock) is that the blacktop has a smoother power curve than the silvertop. also, aside from the internals, the ITBs on the blacktop is slightly bigger than the silvertop. you can also run open throttle bodies on the BT kinda like a carb-d set-up.
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 04-28-2004, 03:41 PM   #11 (permalink)
View Kensuke's Photo Gallery
That being said...we get stuck with AFM most of the time.
Goddammit.
- 1991 Camry SV-21, 3S-FE - "Shinji"
Kensuke is offline   Reply With Quote
Old 04-28-2004, 04:45 PM   #12 (permalink)
You can convert to MAP if you really wanted to using a MegaSquirt or somthing
Old 04-30-2004, 09:21 AM   #13 (permalink)
^ or you can look for a blacktop or any MAP type ECU for your engine and get a sensor.... open ITBs, hehehe!
Deep... do you know anyone that had successfully assembled a MegaSquirt? i know it's a cheaper alternative but i'm not very good with electricals, hehehe.
Old 04-30-2004, 05:41 PM   #14 (permalink)
No, but I was thinking of trying it out. Try Toronto Supra Club though, I *think* I heard sombody was running it there.
And I suck at electrical too
Old 04-30-2004, 06:00 PM   #15 (permalink)
MR1
go hit up www.mr2oc.com
there's a whole section of the forum devoted to megasquirt
