Technafit SS Brake Lines: impressions, problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-27-2004, 11:36 PM   #1 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
Installed my SS brake lines from the group buy, tonight. Well, half installed...
Overall it's a fairly easy procedure to do, provided you have the right tools to get at and around the brake lines, and you don't mind smelling like a funky combination of brake fluid and Lava soap afterwards
I'm not going to go into a howto cause really it's super easy. Look in the haynes manual, that's what you need to do.
However....
I had some problems with these lines.
First off, the lines are apparently in standard units, not metric. Not a biggie, but caused some head scratching.
Second, the grey clip pictured here
There was no replacement clip with the lines, and the OEM retaining clip is too thin... I had to bend up the clip to make it actually work as a retaining piece.
Third, referring to my "half-installed" comment, I could not install the rear lines to my drums due to the following
The more astute of you will notice that the long black piece on the SS line gets in the way of allowing me to actually bolt that black bracket to the car and still be able to hook up the brake line... And even if I wanted to fiddle with it and just leave the thing unbolted, I attempted to just finish the install minus that piece and discovered the line will not fit into the drum end of the SS brake line. I didn't really force it, so it may have been user error there, but that plus the non-bolting aspect (the little black bracket) were enough for me to just say, "fuck it" and leave the rubber hoses on for now.
Having said all that, my impressions with just the front SS lines:
Pedal pressure feels more solid now. Less squishy. Normal braking seems about the same, but hard braking shows a definite improvement. Interestingly enough, the brake release seems improved as well, even after hard stops.
It's really hard to say that these have dramatically improved my stopping and brake-control, cause I'm trying to avoid placebo effect... also, I bled the brakes so that will affect my impressions anyway. However, I will say that there's enough of a difference that I can notice a change in my braking style... not that it feels like a new car or new brakes, just, well, different. Better.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 04-28-2004, 01:14 AM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
wow brink, cant believe that shit doesnt line up... im pissed at technafit for that... maybe luis can talk to them and work something out... i'd say just leave it unbolted anyway... i dont think it will hurt anything. how bad is the fitment on the threads? cause my front ones were a bitch to get on... you might just need to try harder.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 04-28-2004, 07:13 AM   #3 (permalink)
not actual size
brink's Avatar
Yeah, it was really frustrating. It could very well be that I wasn't working at it enough to get it in there so I won't say definitely that the hardline off the drum is not going to screw into the the ss line.
I'm not super concerned about the rears, but it'd be nice to install them seeing as how I paid for them and all Anyone else installed theirs yet? Any problems with rear drums like I had?
Edit:
one other benefit of installing these I just noticed: my forearms are all pumped up from torquing all the fittings. My arms are all beefy Actually, they sort of look like Popeye arms -- but still,
-- Jonathan W.
Old 04-28-2004, 12:01 PM   #4 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
That sucks Brink! I've been busy and haven't gotten a chance to get the lines installed. Judging by your pics, I don't think your gonna have much success forcing them to fit
I guess that "surprise" I sent you helped give you the energy to torque the nuts
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 04-28-2004, 12:46 PM   #5 (permalink)
Guitars and Cars
Chris Corolla S's Avatar
View Chris Corolla S's Photo Gallery
Originally posted by Phi
I guess that "surprise" I slipped you helped give you the energy to torque your nuts
Chris Corolla S is offline   Reply With Quote
Old 04-28-2004, 01:54 PM   #6 (permalink)
not actual size
brink's Avatar
Hey now... It was an Oh Henry!
and lube
-- Jonathan W.
