5SFE Valve Cover Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-29-2004, 02:02 PM   #1 (permalink)
edud NT laiciffO
View KILLACAMNY's Photo Gallery
92 Camry i-4
I want to remove my valve cover to change my gasket and paint the cover. I know the bolts are where the spark plugs go in. After removing those, should the cover come off easily or are there other components that need to be removed?
KILLACAMNY is offline   Reply With Quote
Old 04-29-2004, 06:53 PM   #2 (permalink)
View Adam H's Photo Gallery
The spark plug tube nuts are the only thing that holds it on, as far as I know.
Adam H is offline   Reply With Quote
Old 04-29-2004, 08:53 PM   #3 (permalink)
View gcs118's Photo Gallery
Chances are the cover will be kind of stuck on even after the bolts are removed. Either use a piece of wood and a hammer or a rubber mallet to knock it loose.
gcs118 is offline   Reply With Quote
Old 05-06-2004, 10:34 PM   #4 (permalink)
View mykngdom4avvti's Photo Gallery
gcs118's idea of tapping on the valve cover with a rubber mallet is the best way to remove the cover. I sometimes use a slotted screwdriver and CAREFULLY put it between the cylinder head and valve cover. Pry up a bit on the screwdriver in several places along the cylinder head and you should be able to just pop the cover right off with your hands.
I did this same thing about a year ago-paint the valve cover-and it looks great. When you're done, it will make a huge difference in the appereance of your engine.
B Kent
mykngdom4avvti is offline   Reply With Quote
Old 10-02-2004, 07:57 PM   #5 (permalink)
Banned
View fiveSFE's Photo Gallery
does anyone have pics of where the bolts are, i breifly looked for em yestarday and i couldnt see anything
fiveSFE is offline   Reply With Quote
Old 10-02-2004, 08:16 PM   #6 (permalink)
You have to remove the spark plug wires to see them. They are large and each in the four spark plug holes.
Old 10-06-2004, 10:50 AM   #7 (permalink)
Newbie
smokey8890's Avatar
View smokey8890's Photo Gallery
its the black rings on the you see after the wires. Just use a large socket.
I miss my camry....................
smokey8890 is offline   Reply With Quote
Old 10-06-2004, 10:59 AM   #8 (permalink)
View victor's Photo Gallery
^^^ 30mm socket to be exact. don't forget to take out the rubber seals under the nuts, or the valve cover will not move. good luck.
victor is offline   Reply With Quote
Old 10-08-2004, 07:42 AM   #9 (permalink)
trebor_9513's Avatar
View trebor_9513's Photo Gallery
Talking
what are you painting the cover? Post a pic I'd like to see the outcome.
trebor_9513 is offline   Reply With Quote
Old 10-09-2004, 03:32 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://www.autozone.com/servlet/UiBr...3d8013e886.jsp
"Skoolin' the unlearned!"
