Supra Calipers on an mr2??? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 04-30-2004, 01:47 AM   #1 (permalink)
View jdmsw20's Photo Gallery
Lightbulb Supra Calipers on an mr2???
I was wondering if anyone knew if Supra brake calipers would fit on an SW20 mr2, and if so what work would have to be done to do so......cause i know that for most Nissan applications you can swap the larger 300zx calipers and they will work, and I didnt know if that would be the case here as well. Thanks
dont be scared of too much power, be worried about loosing without it!
jdmsw20 is offline   Reply With Quote
Old 04-30-2004, 07:49 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
please dont cross or dbl post.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 05-06-2004, 08:50 PM   #3 (permalink)
View mykngdom4avvti's Photo Gallery
A caliper is a caliper right?
I think putting Supra calipers on an MR2 would probably work if you could find a pattern to follow on mounting. Some welding and machining would most likely be needed and should probably be done professionaly so the welds don't brake under hard brake application.
The other thing to worry about would be the swept area of the rotor. What is the good of having Supra brakes if only 30% of the pad is touching the rotor. Or, you also wouldn't want more braking pressure on one pad than the other; this might happen if the caliper is mounted cocked over to one side.
and, are the calipers going to clear the rims?
B Kent
mykngdom4avvti is offline   Reply With Quote
