new 3.3L specs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Hardcore Tech and Competition
Hardcore Tech and Competition Strictly HARDCORE tech info and questions and also autocross / racing discussion!
Old 05-07-2004, 08:14 PM   #1 (permalink)
View mykngdom4avvti's Photo Gallery
new 3.3L specs
Just thought I'd post this info on the new 3.3L engine in the Sienna and Highlander right now, and will be coming to the Camry soon.
V6-3300cc- 3MZ-FE
24 valve DOHC with VVT-i
Bore and Stroke: 92.0X83.0mm (1MZ-FE was 87.5X83.0mm
Compression: 10.8-1
230 hp@5600RPM (1MZ-FE 210@5800)
242lb.ft.@3600RPM (1MZ-FE 220@440)
Timing: Interference engine
New VVT-i valve timing and cam profiles
Valve adjustment via shims on top of followers.
32 bit ECU
Rated as ULEV-II
B Kent
mykngdom4avvti is offline   Reply With Quote
Old 05-08-2004, 08:59 AM   #2 (permalink)
Formula One Fanatic
andyman61's Avatar
View andyman61's Photo Gallery
it's already in the gen 5 camrys. my buddy's older sister just got one and claims it pretty damn fast. i think toyota only rates it for 225 hp on the se camry's though.
Metal to burn, sparks to fly...
1992 Toyota Camry 5 Speed - 5S-FE....totally stock
andyman61 is offline   Reply With Quote
Old 05-08-2004, 02:49 PM   #3 (permalink)
cam2Xrunner's Avatar
Are you sure it's an interference motor? I know the 1mz isn't an interference motor.
Old 05-10-2004, 08:29 PM   #4 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
I've heard from at least a half dozen sources that the 3MZ is in fact, an interference design. You're right about the 1MZ, though, and this would seem all the more strange since the 3MZ is, in essence, a bored out 1MZ. Maybe they just got more aggressive with the timing and geometry of valve operation.
ekpolk is offline   Reply With Quote
Old 05-10-2004, 09:17 PM   #5 (permalink)
4u2nv
kasimmmmm's Avatar
View kasimmmmm's Photo Gallery
interference motor? wut do you guys mean by that???
i have a 3MZ-FE in my gen5 but it has 225... not 230.
kasimmmmm is offline   Reply With Quote
Old 05-10-2004, 10:08 PM   #6 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
if i remember right, interference means the valve are angled closer to the pistons.
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 05-11-2004, 05:04 AM   #7 (permalink)
The Regenerator
ekpolk's Avatar
The 3MZ being an interference design may result from a change in geometry. The meaning of this, though, is that upon a failure of timing (the timing belt breaking being the usual culprit), the valves will actually strike the pistons before the engine stops. As you can imagine, this is not good for overall engine health (and makes replacing the timing belt pale into insignificance). Being "non-interference" is just a safety factor not enjoyed by the interference designs. So you 3MZ owners need to be especially careful not to mess with TB change intervals.
Old 05-11-2004, 10:06 AM   #8 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $696665
iTrader Score: 6 reviews
View EKam's Photo Gallery
I heard all VVT-i and VVTL-i engines are interference, someone correct this if I'm wrong.
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
